Car is really starting to piss me off. I'm not quite sure whats going on now. Got rid of the vibration (check my other thread not more than a page back), was all good for about a day or so and now I have this slight sound of something rotating, my friend said it almost sounds like rubber flexing but I can feel a grown coming from the front end. Jacked the car up today and check each tire but keeping one on the ground and the other in the air. Drivers side was fine, a slight bit of vibration but nothing I wouldn't consider normal for a wheel being spun in mid air. The passenger side though was vibration pretty bad, I was inside the car and could feel it and my dad said the wheel was shaking side to side. From this I could only figure tie rod but its a brand new tie rod.....Also when I grab the wheel I can get some side to side movement but ONLY with the tire on. I don't have enough leverage to move anything down there without the tire on. With the tire on though if I force the wheel side to side I can get a slight bump which looks like its coming from the steering rack, again I'm not sure though.
The whole front end is pretty much new, parts that are new or newish are: transmission (built by billboost), shocks and springs (GR2 and SSC, the entire assembly is brand new), motor mount, both axles, both front wheel bearings, lower ball joint (pass. side), I have spacers for being lowered.
I'm pretty lost at this point and pissed off even more, give me a hand and let me know what to check because at this point I have no idea....
