Yella Terra RR install ISSUE!
SleeperGS
I installed my YT rollers last night; atleast in the front. We noticed the that back of the rockers were about 3/8 of an inch from the push rod. We even barley, and I mean barley, cranked the motor over a few times and the rocker would not touch the springs/valves. I done some searching and found on Intense's site and found this... I hope to help others if they run into the same problem as I thought I could use stock pushrods. Well you can use them, if they were modded 1.9's, but when you go YT RR's, you need the increased length. I can only find them at intense-racing unless I overlooked them on other websites. Stock length is 7.05" and the ones I apparently need are 7.30".
  • PRL-705 - INTENSE Lightweight Pushrods, 5/16" x .049" X 7.050" set/12 (Stock Pushrod Length)
  • PRO-705 - INTENSE Oil Restricted Pushrods, 5/16" x .083" X 7.050" set/12 (Stock Pushrod Length)
  • :th_lightbulb:PRO-730 - INTENSE Oil Restricted Pushrods, 5/16" x .083 x 7.300" set/12 (Yella Terra Pushrod Length) :th_lightbulb::th_lightbulb::th_lightbulb::th_lightbulb:
  • PRE-705 - INTENSE Extreme Duty Pushrods, 3/8" x .083" X 7.050" set/12 (Stock Pushrod Length)
This is why my stock pushrods were/are to short...I guess. Hope this helps, and her goes another $100.00 smacks!
Pushrods come right out, just make sure they go back into the same hole that they originally came out of. Line them up to keep track of them.
I didnt get them. I bought used rockers off my local craigslist and all that came with them were the rockers, and pedistals, no push rods. The guy I bought them off of seemigly forgot to tell me that I would need to get them and or they didnt come with my purchase. No trick question of the sort, just trying to head those off that steer away from the $400.00 purchase of the YT's but may be inclined, such as I, to buy used ones; hopefully if they do they wont get schmoozed by someone like I did so they can get the pushrods along with the rockers.
