    TIPS:
WTB Steering Wheel Position Sensor 05 GXP with JL4 active braking (stabilitrak)
05gxpia
Needing the SWPS shipped to 51010. Email me or text seven one two 4 2 zero seven 687
This part is located at the base of the column and would need to be removed carefully and kept in time before/after removal to be usable.
Thanks in advance.
Brian
Re: WTB Steering Wheel Position Sensors 05 GXP with JL4 active braking (stabilitrak)
You can edit it yourself. Click on "Edit Post" and then "Go Advanced" and you can edit the title.
Thank you 4thgencamarofan
If the vehicle was equipped with stabilitrak it would have it. Also known as Active Braking, JL4. If you look at the base of the column itself you will see a black sensor with about 3 wires in it. If it didn't have a white plug there. Thanks for the reply.
Brian
I've got one, shoot me an offer, and instructions on any special handling needed to remove / ship it.
I have a parted out 04 CompG sitting here with a complete column, sensor still intact.
-Rob
