    TIPS:
WTB:Modded retainers,130lb spr,pushrods,map sensor, more
Sirayden
Still need a few parts for my "budget build" so looking for good used stuff.
Need:
Modded retainers
130lb springs (or similar)
Upgraded pushrods, stock length
Re-usable rocker arm bolts
Double-thick timing cover gasket
Big degree wheel
Preload checker (need when using ls7 lifters?)
May need:
Map sensor for turbo boost over 20psi
New rod and main bolts which won't need machining
5/16-18x1" flywheel bolts (not a flex plate, will be manual trans)
Hp tuner
Alternator relocation bracket
98-99 Monte Carlo/Lumina Z34 engine harness
I realize some parts are for other vehicles but it doesn't hurt to check. Let me know what you have. Thanks!
