    TIPS:
WTB: M90 rotor pack
BrandonHall10
Solving problems
Short version: I need just the rotor pack from an M90.
Long version: I have an MP112 charger with some missing gear teeth. The M90 and M112 share the same gears. I thought someone here might have a junk M90 sitting around needing a purpose. It looks like the rotor pack by itself will fit in a medium flat rate box. I'd hate to ruin a perfectly good junkyard supercharger just to rob the gears. Would be shipped to 85747.
Thanks.
attachment.php
Yes, but I don't think I've pulled one out before. You will have to be specific on what you want and how to pull it out. You can PM me more info or your contact info.
After the snout is off, does the plate with rotors just pull out? Maybe with a tap and/or pry?
I believe so. I personally have never had a charger fully disassembled. but it looks like the front bearing plate is just sandwiched between the snout and case. After the shout is off, the only thing holding the rotor pack in is the sealant. A little tappy-tappy should get it out.
Looking for just the assembly seen in the attached picture.
I will PM for financial details.
