    TIPS:
WTB M90 housing cheap
andesmint
Hey, I don't necessarily need this part myself, however myself and some others are curious as to whether the silencer ports can me plugged bassically the same way as in the "correct way" thread. The only difference is... I'd be welding it in. I know the is a risk of the housing warping or cracking, and that is the point of this test. I want to see just how much welding we can get away with before the housing becomes distorted. I'll be doing a write up of it on here. So to sum it up i will do a few welds, test the rotors in the housing, then do a few more if it still isn't warped. this process will be continued until either the housing warps or i magically run out of places to weld and it is perfect. I know how to weld cast aluminum w/o cracking it so i'm not worried about that. Please PM me if you have one that you are willing to part with cheap. if its too much then I just wont do it.
Thanks
i have a M90 case, from a 97. Outlet was ported with a dremel, would be good for whatever you plan on doing to it. Will probbally cost an arm n a leg to ship it to you tho. hmu if intrested
I got offered a housing for the cost of shipping from somebody. sooo purchase pending? idk lol
thanks for the info snow. ill get back to you if this deal falls through speedy
