    TIPS:
WTB Aeroforce Gague for 1997 GTP
Do you need the "Performance option" ie the 0-60/1/4mi results, on the gauge?
I have an extra secondary gauge that reads all the options but won't do the performance options because that is only available on the primary gauge.
Black face with GTP logo, red display.
I'm %100 sure it does, but I will double check in the morning. I bought a Triple gauge set (1 primary, 2 secondary) but the 05 data rate has a problem updating 3 gauges so I have an unplugged one in my triple pillar pod unused that I was going to eventually list here. I also have a single and a double dash mount pod, as well as Sunpro volt/pressure/temp/boost gauges if you want more cheap gauges.
As long as it does KR, can work by itsself, and works with the 97, it sounds good. Can I get a part or model number when you get a chance?
Are the sunpro gauges 52mm?
It's a PT-402. Works on my 96 Corvette, 01 Explorer, and 05 GTP so it's supposed to work on a 97 GTP. All gauges and pods I have are 52mm. I have the factory box and cables for the Aeroforce but not bracket that secures it from behind since I cut that smaller to fit in my custom pods before I got my piller pod. I just use electrical tape to make the gauge a little bigger to stay snug in the pod.
Here's a pic of what I'm selling him per the rules.
attachment.php
Aeroforce PT402 with all cables,box,instructions but no mounting hardware. Sunpro bare volt meter and boost gauge with all hoses and fittings and mounts.
