    TIPS:
WTB: 00-02 Stock GT PCM
Yonkerse
Hey Guys,
I have had an odd hesitation issue with 3rd and 4th gears during acceleration. (01 GP Gt with 205k) Car shifts into gear fine and when given more than about 15% throttle the RPM's jump all over and car has an odd pulsing acceleration behavior. I have tried and replaced all sensors and nothing has affected it.
I want to try swapping PCM's to see if it affects anything. Really have no idea what else to try.
So wondering if someone has a stock 00-02 GT PCM for cheap I can buy, or if local to Saginaw, MI (zip 48609) I can try. Like I said, I'm stumped to this point and trying random things now.
Let me know. Reply to thread or PM me please.
Thanks,
Eric
Reptile,
Is this located under the side Trans cover? Would this throw any codes if malfunctioning?
Thanks,
Erif
Yes, those solenoids are under the side pan, not really hard to get to, just time consuming, their not relly all that expensive eithor....
And speaking from persona experience, it will throw codes, but you won't get a CEL or anything. Hook a can tool to it, and do a real time scan as you drive it.
It has to be pretty severe to throw a code. The easiest way to change it is pulling the axle out, supporting the car on jack stands, and then lowering that side of the cradle. You can change it without doing that, but you risk dropping the retainer clip into the pan, and then you're really gonna have a good time.
