Write-up/tech tips for Ignition Switch bypass procedure?
I replaced the ignition switch on '02 GP. After getting the new switch in place, I want to do the ignition switch bypass procedure so that the current will bypass the contacts in the ignition switch itself and flow through the relay. Is there a write-up on how to install and wire up the relay for this?
Thanks for the quick response.
I was searching for BackInBlack's post on this ignition switch bypass procedure on ClubGP, but had no luck (searching on ClubGP for old write-ups is difficult at best). There is a thread on the bypass procedure under the write-up section, but the link to the procedure would not load.
Anyways, I will locate the relay and wires and get this going. I had an ignition switch from an another GP that I installed into my 40th Anniversary GP and so far, the contacts are showing no signs of going bad.
No problem. I just did this to my new uninstalled switch a few weeks ago. FYI, the write-up is in the "Upgrades" section of ClubGP.
Yet. LOL
