Would this work?
GTPcoupe
Well I'm a bit of a wiring newbie, but I believe this should work. I have my boost gauge setup and I just need to do the lighting for it. I want to power the lighting same way pretty much as I did for my Aeroforce gauges.
If I run the power wire to an add-circuit by little fuse plugged in where the steering wheel control illumination fuse is, would that work same was as if I would have spliced into the dimmer switch? Also, I'm not sure where I should screw in the ground wire? Sounds pretty simple, but I just wanted to be sure.
The fuse used for the steering wheel controls illumination is 2A. What should I plug in the other slot for the boost gauge light? Another 2A? 10?
The gray wire off your dimmer switch. pull your headlight switch turn it up side down and it is the second wire on the bottom row lil gray one..
