wont start
OKay.... well the regulator is good and i have 50 psi at the rail now. (must of been a bad test before)
I pulled out my spark plugs and they were shot... so i put new ones in. They were covered in gas and had all kinds of build up on them. My MAF sensor was bad so i think it was putting too much gas in. SO before i put in my new spark plugs i did a compression test.... i have 150 across the board except the front middle cylinder which is giving me 0!!!!!!!!! :( I dont like it... But if it was a head gasket wouldnt i get lower compression on more than one? the other five are fine!.... maybe its all gummed up and clogged from the gas/carbon built up. When i did the pressure test it was sucking up all kinds of build up. So what do you guys think? hopefully not a head gasket..... :( i don't have the money to fix that
Pump compressed air into that cylinder and see if you can hear any leaks or see lotsa bubbles in the radiator... My guess would be a burnt exhaust valve or bad test.
