i'd spin the engine so cly 1 is tdc and see where the cam lobes are, im pretty sure they should both be in the closed position., if you drop back in 2 lifters for cly 1, you should be able to tell where the lobes of the cam are.
any way you look at it something is way off some how some where. i've never seen every push rod bent or broken.
it would be a trip if you got a boat engine cam shipped to you, most boat engines run backwards.
Are you sure that your timing marks are lined up?....because from that picture you posted, it looks to me like they are a tooth off.
I'm pretty sure it can.....and has in the past.
Explain how that's possible on our motors please. Because I'm not aware of it being possible.
Maybe from repeated trying to start the engine you had so much fuel in there it hydrolocked and bent the pushrods? About the only thing I could think of if the timing was correct. Other questions are what Springs and what rockers are you using again?
Just disable fuel and spark and crank it with the starter
