Wiring stock H1 bulbs in my retros..
jayroca
Banned
Grabbed some stock h1 bulbs from auto zone and wanted to wire them with my retros until i grab hids again i have this h1 connector but where do i wire it to? Im familiar with positive and negative but this is odd to me thanks
Sent from my LG-E980 using Tapatalk
Lol...Let me rephrase not the plastic metal that connects to the bulb bill..lol where does the wire connect to?
Im confused, so your using a halogen H1 bulb untill you can get your get your HID kit and wondering how to connect it to make them work?
Sent from the Milky Way
The bulb has 2 wires coming off it right? Just wire them to the stock connector for the low beam. Problem is you wont have high beams untill you get the relay harness because you wouldn't be able to power the solenoid for the cutoff without doing some fancy wiring I think. Also I don't know how well they will work in the projector. Mini h1 right? Do they fit in it?
Your probably just better ordering bulbs IIRC to for h1 halogen bulbs in the Mini h1 you'll have to modify the bulb. Seems like a lot of work when the simple solution would be order another set of bulbs :) unless I'm missing something.
I say grab an el cheapo vvme kit or equivalent, then save for some from like TRS or whatever you want.
Yeah they fit perfectly its one wire smh thats what got me lost
Dont have stock bulbs or headlight need a fix till hids come in..
Halogen H1 bulbs are self grounding, so the wire goes to the 12v headlight wire. Never seen one with a pigtail on it.
^ which would be a problem because you have no way to ground the bulb unless you add a wire to it and ground it to the frame or headlight connector right.
If thats the case i'll wire it to my headlight harness 12v
Correct i wouldnt i didnt know exactly what to do with the wire but i'll wire it tomy headlight harness
Update..
Well the bulbs are wired and everything is a ok until my HIDS and replacement HID relay with Halo Rings come in the mail.. for my h1 stock bulbs ended up having to stick a spliced ground wire between the light and my retrofit housing and ground it to the car and the positive i wired with my gauges so my lights come on when i turn the ignition so headligh is fixed not pure white like i like but it'll work
