Im confused, so your using a halogen H1 bulb untill you can get your get your HID kit and wondering how to connect it to make them work?
Sent from the Milky Way
The bulb has 2 wires coming off it right? Just wire them to the stock connector for the low beam. Problem is you wont have high beams untill you get the relay harness because you wouldn't be able to power the solenoid for the cutoff without doing some fancy wiring I think. Also I don't know how well they will work in the projector. Mini h1 right? Do they fit in it?
Your probably just better ordering bulbs IIRC to for h1 halogen bulbs in the Mini h1 you'll have to modify the bulb. Seems like a lot of work when the simple solution would be order another set of bulbsunless I'm missing something.
Halogen H1 bulbs are self grounding, so the wire goes to the 12v headlight wire. Never seen one with a pigtail on it.
^ which would be a problem because you have no way to ground the bulb unless you add a wire to it and ground it to the frame or headlight connector right.
