Iron Indian
Guys,
The other day my 880 HIDs (fog lights) were randomly working. I checked my ground and connections and all were secure like they should be. I figured out the problem... I touched the relay and the lights came on. The relay had corrosion on itself and the connector. Obviously it ain't weather resistant. The fuses ain't either although I haven't had a problem with them yet, there was a little corrosion on the spades too.
So my first question is, whats the best way to clean the corrsion off the relay, fuses, and connectors? I assume baking soda/water will do the trick, any other suggestions? As for sealing everything from the weather/water, what can I do? I don't want to silicone everything because the relay + fuses may need to be replaced in the future. Only thing I can logically think of doing is using dielectic grease on the connections and electrical tape. What do you guys think? Any suggestions? I'd like to solve this problem for good.
Thanks...
Thanks...
