Wiring Harness Question!
You guys are awesome. Took me a while to find a thread like this. Thanks so much. This is good for both single and double din stereos correct? As i have a double din just sitting around. :)
I would save yourself the trouble and just pick up the gmos-04. Retains everything, chimes, onstar, etc. Can be picked up on ebay for 45$. Also has a 12v switched source wire. Very easy install
i installed this headunit so yes
@des19
so would it be different if used a gmos-1 instead of a gmos-4 since my car is not amplified?
@2dee11
Wow, that thing is nice. New Pioneer model? Does your unit still stay on until you open the door when you turn the car off? where did u get the 12 volt for switched power? Pic?
i have a 2005 base model, so this could be a little different than yours. i used:
this harness adapter Amazon.com: Metra 70-2003 Radio Wiring Harness For GM 98-Up Harness: Car Electronics
with this antenna adapter http://www.amazon.com/gp/product/B0002BEQN4/ref=oh_details_o01_s00_i01
with this dash kit http://www.amazon.com/gp/product/B0014GII0I/ref=oh_details_o02_s00_i01
aswell as a similar add a circuit from autozone (or loca autoparts store) like this one Cooper Bussmann/ATM fuse tap converts one into two fusible circuits - 10 Amps maximum on added circuit (BP-HHH-RP) | Fuse and Accessories | AutoZone.com
i did end up losing my door chimes and onstar, but this was no problem for me because i hated the chimes and never used onstar...
i got my switched power source using the add a circuit in the "sun roof" fuse on the passenger side fuse box (i dont not have a sun roof but all grand prix's have this so ive been told)
closer view
i just ran the wire hidden up under the dash to the head unit
finished pics
yes the radio does stay on until i open the door after i turn the car off. The model is the Pioneer AVH-P1400DVD
I hate that they put the USB port in the front of the radio I think it looks cheap to have wires coming out IMO. I personally wouldn't spend that much on a unit that does that. But I'm glad u got everything working I will be installing a double din soon also
@des19
@2dee11
The gmos 1 works the same way as the gmos 4 except the 1 is for non amplified gm vehicles. The gmos-01 will also just be a plug and play install very easy and retains everything except wheel controls. For this u need a separate adapter like a PAC module. gmos-01 is the way to go very easy install will definately save u a lot of headaches.
@2dee11: so i found the add a circuit. do i put two 10a fuses or do i put the 10a fuse on the top and the 20a fuse on the bottom?
@des19: sop i've been looking for a harness but they all seem to be 70 and up. any specific retailer i should look for?
i agree i realized this about a week after i got it, but oh well!
@spac31 umm... i think it just depends. my add a circuit was capable up to 20A i think and i put it in the sun roof which is 20A so i put two 10A fuses in it
Okay so if i pull my stock stereo out to plug in the new wire harness and make sure it works, will it lock up on me?
I don't think so.. I took mine out then realized I had forgotten a CD in it and plugged it back in to get it out.. seemed to work fine when I plugged it back in
sorry for the late response, i've been busy with finishing up school this past week but yes i did bypass it
THanx guys... Decided to go with the metra harness, (didn't really see the need for the on-star or warning chimes) and I managed to fix the whole parking brake thing.
I was wondering if with the harness are you still able see you km you have driven, are you able to see Trip A and Trip B feature, and do you still get the warnings for oil changes and stuff? I wanna change the radio but i dont wanna lose the km feature, im not really worried about the calendar.
Yup that all remains
Only thing your losing is the calendar feature but hell that's what a cell phone is for.
