Wiper Blade Position
aubry118
Well I have another anomoly with my 2000 GTP. The new windsheild wiper park position is now at 12oClock. Do any of you guys know what is causing this and what is required to repair.:th_scratchhead:
More than likely the bolt that holds the wiper arm. They loosen up a bit and they loose their position. Mine does that every once in awhile. Turn wipers off, turn car off, open hood, pop off plastic bolt cap on bottom of arm, 13mm bolt. Loosen bolt, move wiper arm down by hand then tighten bolt. Hope this helps.
