Windshield Squirter Help
TCO
My windshield squirters did not work so I put a new pump in and they worked fine for a couple days. I went the other day and they did not work. Someone said that their could be foil from the top of the washer fluid bottle in the tank. Does anyone have any other ideas?
If it is foil, do I have to pull the whole tank out to flush it?
Thanks
The only thing i an suggest is kind of trace it down the line. Find out where exactly it stops squirting and that is probably where the problem will be.
if it is the squirters themselves...
get a glass of vinnegar and water and let them soak overnight. this will clean all the calcium deposits, and gunk out of them.....
I'd pull the hose off the squiters and see if it sprays ou the hose...
