Window tint
Try degresser I used it to take off my tint, I sprayed it on the window put a bag on the window left it over night it peeled off clean and windex of the rest.
Sent from my SGH-M919 using Tapatalk
My back window starting to bubble up and turn purple... Had them tinted back in 05. wonder if I should just tint over them rather than removing them and starting over??
Itd probably look worse, I'm going to try to get mine off when the weather permits
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Ok scottydoggs I tried the Steele wool with soap and water, alcohol, purple power, ammonia,paint thinner and it did not budge at all, whatever is on it is hard and like tent and will barely flake if I use my finger nail
Get large garage bag open it up with a razor knife. Spray down the window on the tint side with degresser. Let it sit over night then peel off everything.
Have you ever heard of purple power? It's a degresser and wonder if it's strong enough, I know I used oven/grill cleaner on my motor and it works, wonder if it will work good?
Yea, I used the cheap stuff and it worked just fine just spray it on generously and let it sit
Ok I'll do it closer to Dark so it ain't so hot during the day, it's raining here so I'll post back when I try it
I got the bag on it and it's been on awhile and it's stuck on there good, when I peel the bag off will the tint or what's left of it come off with it or will it scratch off easy or what
Yeah it'll come off in one piece the glue will get dissolved and a Terry clothe will wipe it off clean
Ok I know it's been at least 6 or 7 and I'm getting up and trying it and hope it works
