All,
I just did some repairs this weekend to my 01 GTP. Coolant elbows, wheel bearing / hubs and a window regulator with motor on the driver's side.
I had 20k on my recently replaced MOOG from wheel hub bearings and the passenger side went bad. Turns out that MOOG has a 3 year warranty so I got the hub replaced for free. I had a slow coolant leak so I changed the coolant elbows and it turned out that one of them was cracked by the o-ring. Wheel bearing and coolant elbows turned out to be a success.
My driver's side window did not want to go up sometimes so I changed out the window regulator and motor today. I think I might have misdiagnosed the problem as I it happened once later today while running some errands. Could it have been the switch instead? I did not think the switch was the problem due to the fact the window would not go up or down when I would encounter the problem. I figured if it was the switch that only one direction would be an issue and not both at the same time.
Do window motors typically stop working all together? Could my window switch still be at fault?
Thoughts?
Thoughts?
