Will the turbo
And I look at it like this if I can get the thing to hook like I can now on very bald street tires then I can get it to hook turbod on some dr's. axles may not like it but I will :) and if you say no you won't>>>>>> challenge accepted :)
Your car will give you the illusion that you can hook because your still on a stock tune that story would change if trans abuse mode and tourqe management were taken out of the equation
He's right it will change dramatically...
Sent from my iPad using Tapatalk HD
it wont hook for **** on the street making any sort of decent power, my 04 weighs about 3100lbs and blows off 10" wide et streets at anything under 55mph, thats with my boost turned down around the 475whp area, first gear is un useable on the street
True didn't think of the tq management and all the goodies lol, I don't plan on that much just hoping for 400 I would be set!!! How does your car do on 400 with the Et's and I weighed my car with my girly in it it was 4k and she's 120 lbs so how are you that light?
that was with just a turbo kit and an st5 cam on a stock l26 it made 522whp before it ran out of fuel pump on e85, its now an l67 8.3:1 comp, st3.5 zzp heads, st5 cam set up to spin 6800rpm, dual 320lph fuel pumps, it should be in the 650-700whp range this summer im waiting to get my trans back from a refresh, i had it together and running but i mistakenly knocked the clutches off the 4th gear hub when i installed the channel plate and didnt know so the trans came back out, and as far as weight, there is pretty much nothing on the car the only thing that runs off the belt is the alternator, there is alot of weight taken out id like to spring for a race seat but i doubt that will happen
this is with the boost turned down to 15 lbs it made 522 at 17.5lbs every pound of boost is worth in the ball park of 25whp at that boost range on the turbo set up i have, this little pull was done with my 9" wide mustang rims with 275/40/17 nitto DR's they are every bit of 10" wide i now run et streets, you can see the spin from 45-65 on the spedo as well as hear it in the back ground
Very nice pull sir!! Is that a open downpipe or?
And as that is true this is what I have to work with right now!!! I will use it to find out my oil line locations my intercoolers pipes and where the flange is suspose to go if I have to use my stock crossover
