Will Steel Wheels from a 2000 Dodge Caravan fit on a 2002 Grand Prix?
phogstenjr
I believe the Caravan wheels are 5 X 114 and I believe the tires are 215/65/15 or possibly 215/65/16?
The minivan is broke down in the garage and the tires are in really good shape. If they fit on the Grand Prix I may through them on just to get me through the winter.
they should fit
the dodge and the GM wheel bearinhgs are identical except for the rotor pilot dia (same spline, same 3 bolt pattern, same threads), the wheel/hub pilot dia is identical. dont worry about the 5x115 vs 5 x 114,3 bolt pattern stuff...its a moot point.
ive seen jeep wheels on the C body's and from the fitments id say your fine
for posterity's sake i had to do wheel bearings on my 98 intrepid and i had a spare GM hub laying on the bench.
1st gen crosslaces fit on the dodge, dont see why you couldnt put the dodge(or ford) 5x4.5 wheels on a GM
if they are 15" and youve upgraded your brakes youll have brake clearance issues
