Will it fit?
Tate
Will the exhaust from a 2006 GXP fit on a 2000 GTP? I have access to a magna flow catback system off one and wanted to throw it on the GTP.
Tate
What else would work from a GXP to a 97-03 GTP? I have the 06 GXP that is wrecked in the front and no one really wants it, so maybe rape it and place what I can on the GTP before taking to the junk yard. It would be nice if the Heads-up would swap over.
Tate
Dude. I would love a few things off that GXP interior and a couple under the hood pieces.
And FYI the stock 243 casting heads go for 400 bucks plus easy in the ls community.
DirtDog, PM replied to.
Anyone else have good ideas on what can be swapped over from the 06 GP GXP to a 00 GP GTP?
Tate
If you haven't done your trailing arms already swap the trailing arms. They are a solid square rod style and are a good upgrade from the stamped style ones, and they bolt right in. I have 06 gxp trailing arms on my 01.
**** if anyone wants the trailing and lateral arms off a GXP I have my stock ones. I upgraded to BMR ones
Well the GXP is gone. As far as the original question of this post of will the magnaflow catback exhaust from a GXP fit a 97-03 GTP the answers is yes and no. The cat back itself would fit just fine, but the tips on the MF catback system are dual 4" tips for a total of 8" across. The 97-03 exhaust tip opening is only a little larger then 7 1/4" so the tips wouldn't fit on it.
Tate
