Wife broke the car :(
intake gaskets leak too much water and hydrolock???i know it'll happen on the l36's.. hope u find a competent mechanic.
Well I'm finally back from Iraq and it seems that the wife and I are just gonna cut the losses and sell the Daytona :(.
With the engine "locked" up and my lack of mechanical knowledge to really get a good look at the engine, we obviously won't be asking too much for it.
At least the exterior is in pretty good condition!
I'll get some pictures and a walk around video up of it soon.
start it without the serpentine belt on the car...could have a locked up ac compressor or maybe the alternator, causing the crank not to have enough power to turn the motor over.
Man I know that a locked up alt. can prevent an engine from turning over, it happened to me. The starter just doesn't have the power to over come the alt if it's locked up. I took the belt off and started right up.
WELL!!
I finally looked under the hood to see why the engine didn't start at all. The first thing I noticed was that both the S/C belt and the serpentine belt were off the pulleys. When I looked closer I could see the freaking serpentine belt was wrapped around the crank pulley. Now I'm no mechanic, but I'm pretty sure that was the reason it would never turn over.
I pulled the S/C belt out (it was still intact), but had to cut the serpentine belt in 3 places to get it out, and even then there is still a piece stuck to where I can't even cut it loose.
After that I hooked up some jumper cables to my truck and it started right up. There was a little bit of smoke (burnt rubber) coming from where the cable was stuck.
All in all, I don't know what the hell the mechanic thought was wrong, but at least it can be started now.
Should help sell it, no?
