MUAHHAHAH seriously? What v8 have you seen run low 11s with one? None, because it didnt happen.
What do you have against bias ply slicks? They are by far the safest option in a fiero.
a 140 is abou the right size. Going smaller would just be a pain and not save you any money, and kill any potential resale.
For the money, the whipple may be better, although the TVS would be easier to install by a large margin.
You need to intercool the whipple..... Its a flat requirement due to the way it works.
Its more than just a plate... Its an intercooler, a blower inlet tube, and INTERCOOLED bypass system, 8 rib belt setup.... all in one small space. Its possible just far from being easy.
Ok let's go through this again, thanks to the nay sayer
There are many people using the muncie 282 in their high HP Fieros including cammed ls1's making around 500hp, if that doesn't hold i will upgrade to a f40 form a G6.
My problem with bias ply slicks will add a lot more strain to the transmission and axles, where decently sticky street tires should allow for enough slip to avoid transmission failure.
The reason i'm saying a 100ax vs the 140 is because it is closer to the displacement of the original supercharger but it is much more efficient which would leave me to believe that it would be a better match for the 3800, so that was what my origional question was about it has nothing to do with money or someones opinion.
You are correct the whipple does seam to be putting out better numbers and more proven results compared to the tvs
I don't have room for an air to air intercooler, I'm not talking to under the supercharger
Yes i'm aware that it's more than just an adapter plate, but it's not really that complicated either, just a matter of alinging the supercharger properly finding an inlet tube that will function properly which won't be very difficult for my set up, the only thing that will be difficult is installing a bypass valve but i'm sure i can figure it out without too much difficulty. 8 rib i can get from zzp. It won't be easy but it won't be hard.
I'm not dead set on a Whipple, but i just haven't seen the numbers I'm looking for out of other chargers, or at least ones i can run. But if anyone has links to a build with high numbers let me know.
