It all makes sense though and this is just me trying to understand it...installing the rotors in a "reversed" pattern would actually bite against the pad better resulting in BETTER stopping power vs. installed the direction the wheel turns causes the rotor to just "glide" across the pad when pressure is applied...
Brian or Jay...right...right? I think I get it
I don't know, I don't have them. If I did, unless the manufaturer or the vanes inside required them to be different, I would mount them as Brembo states which would be opposite of how Jason has his. But Jason said his were marked R and L, so his are right according the manufacturer and as I said, every manufacturer may have their own way of doing it.
IMO, if you look at this photo and imagine the rotor going in a forward direction. As the slot comes around, it makes contact with the pad almost flat and closer to 90 degrees. This is correct according to MOST manufacturers, but there are exceptions.
Now, the other thing to keep in mind here is that the slots main purpose is not to "bite" the pad. They do, and they do increase stopping power, but their main purpose is to "cut" the pad, or shave it in a sense. This prevents the pad from glazing during rigorous braking which would usually translate into brake fade. The holes keep the rotor cooler which also helps reduce glazing on the pad. Brake fade = bad, especially if you road race or autocross which is were you see drilled and slotted rotors used the most.
:th_thumbsup-wink:
Now, I have a theory and this is only my opinion, so don't be too hard on me. Jason mentioned that mounting them like this Mustang picture eats up pads quickly. This is probably true. But, if you are a serious autocrosser using these slotted rotors to their full potential, you probably already expect to eat up brake pads like candy and want them to eat into the pad to keep them from glazing over and losing your braking. I think some of these companies purposely have you mount them the opposite direction to keep the number of complaints down about how fast they eat through brake pads on a street driven car. Furthermore, I also think they will work either way and I think you are going to get increased braking ability either way, but it is more dependent on what you want out of them. If they are straight vaned and you want the full potential out of them (and actually have a need for it), mount them like the Mustang above. If you want increased performance but don't want to replace brake pads every other month, then reverse them.
