Jtiger360
My radiator fans stop working, I check all the fuse and relays and they are good. I just order some jumper wires so I can connect the battery to the fan directly, to test the fan themselves. If the fans work I herd that, I can test the radiator fan switch by shorting it out with a paper clip and see if the fans turn on, where is it? If the fans kick in, it is not a bad switch, it could be bad a thermostat, if the fans don't it could be a bad switch. That info sound right to you guys? And if the fans do not come on when I connect to the batt, I got a dead fan motor (time for new fan assembly) I still a noob in training. Thanks for all the help and support!
