Wheel stud length
GotMelon
Any one know what length the factory wheel studs are for 97-03 grand prix. I just did cts v swap and need to run a 1/4 inch spacer to clear my wheels so there is only about 4 threads sticking out of the wheels now. I would like to order longer arp studs.
Thanks
Sent from my SPH-L710 using Tapatalk
OK I didn't even think about that. Not have been replaced I'll pull the hubs and get the studs pressed out and check knurled diameter before ordering thank you
If your hub bearings are old enough I would suggest getting new ones if you're going to spend nearly $100 on just studs. It will also let you confirm the knurl diameter as I found both sizes on both SKF and Timken bearings with most of the cheap units also being larger than the OEM studs
There not very old about 3k miles on them I'm local to summit racing so it's not a big deal if I have to return stuff
