Wheel spacers/hub rings?
do you want wheel spacers or hub rings? they are completely different.
i would check out your local tire/wheel dealers. thatd probably be the cheapest place to find them.
Hub rings would probably be the best, don't they reuse the stock studs to bolt on the ring, and have its own studs to bolt on your wheels?
no. that sounds like a wheel adapater to where you changer you lug pattern. hub rings are thin and they assist with the centering of your wheel when mounted. I reccommend hub rings with any after market wheels.
no. most wheel companies will send you a set of centric hub rings with your wheels if your request then. or go to like a big10 tire or any wheel shop. they will have them set of 4 for like 20 bucks.
now wheel spacers you will lose some lenght of your stud.
