whats good eryone....
I just google abbriviations and usually find out that way. I honestly dont know the words that N/A stands for but it means not supercharged I believe. Someone will correct me if Im wrong. lol
here you go:
General word abreviations
A/F = Air Fuel Ratio
CEL= Check Engine Light
DHP = Digital Horse Power
DP = Down Pipe
DTC = Diagnostic Trouble Code
EGR = Exhaust Gas Recirculation
FTW = For The Win
GMPP = General Motors Performance Parts
GP = Grand Prix
GTP = No one really knows
GTP FTW = GTP For The Win
IAC = Idle Air Control
IPW = Injector Pulse Width
IAT = Intake Air Temp
KR = Knock Retard
LTFT = Long Term Fuel Trim
MAP = Manifold Absolute Pressure
OBD II = On-Board Diagnostics
P&P = Port and Polish
PE = Power Enrichment
PW = Power Window
PFYC = Parts For your Car, An online parts store (http://www.pfyc.com )
SES = Service Engine Soon
SLP = Street legal Performance (http://www.slponline.com )
STFT = Short Term Fuel Trim
STFU = Shut The F*** Up
S/C = Supercharger
TDC = Top Dead Center
WOT = Wide Open Throttle
ZZP = ZZPerformance ( http://www.zzperformance.com )
Mods
Aeroforce = A gauge used to scan multiple parameters using OBD2. (Aeroforce Technology Inc | Welcome )
AFC = Air Fuel Controller
Autolites = Autolite spark plugs
CAI = Cold Air Intake
DHP PCM = Power train Control Module made by DHP
DHP P/T = Digital Horse Powers Power Tuner software, used to tune.
3" DP = Used for Mild Mods (gets rid of U-bend)
FWI = Fender Well Intake
IC = Intercooler
SSI/C = Short Stack Intercooler
ICCU = In Car Controller Unit
MPS = Modular Pulley System
N* TB = The NorthStar Throttle body out of a Cadillac.
PEM = Ported Exhaust Manifold
Plog = ZZPerformance's Power Log ( http://www.zzperformance.com/gra...&catid=110 )
RR = Roller Rockers
T-stat = Thermostat
TB Spacer = Throttle Body Spacer
TOGs = The Other Guy Headers (http://www.3800performance.com/M...ct_Count=1 )
U-bend delete = A U shaped piece in the stock cat back that is very restrictive and is usually removed.
VOM = Volt Ohms Meter or Multi Meter
Wiz = Wizaired Intake (http://www.zzperformance.com/gra...&catid=113 )
Parts
BBV = Boost Bypass Valve
DIC = Driver Information Center
EGR valve = Exhaust Gas Recirculation valve
HUD = Heads Up Display
IAT = sensor Intake Air Temperature sensor
ICM = Ignition Control Module
MAF = sensor Mass Air Flow sensor
TCC = Torque Converter Clutch
TB = Throttle Body
TPS = Throttle Position Sensor
