what pulley?
RICE KILLER
ok so i am about to start ordering parts for my gtp :th_thumbsup-wink:and here is what i am going to do as far as mods.
-FWI
-SSAC headers
-1.9 rockers
-ported TB and SC
-DPH PCM
-180* T-stat
-104 autolites and new wires
-modular pulley system
so i was going to go with the 3.4 pulley but do you guys think i could go smaller? also does any one else have the same or similar set up; if so what were the results?
you need to add a scanner to that mod list and ditch the pcm and get a custom tune to make the most from that setup..noone can tell you what pulley you can run..ive seen ppl with KR from a 3.4 w/ that setup and ive seen others with the 3.3 KR free, every car is dif. this is for a 97-03 setup, if you have an 04+ you wont be able to run as small of a pulley
x2 on ditch the dhp pcm and go for a custom tune
I made that mistake on my car and ending up needing a custom tune anyways. However, it's still better than stock :-)
go for a custom tune. forget the DHP....it has too much timing IMO out of the box and I get knock on a 3.4...I bet I could eliminate the knock if I had a custom tune.
