I would start with a 3.5'' and scan.
And no other mods?
Good call expert.
To add.
Stock pulley > Not knowing if your car is knocking on a smaller one + buying a short block after you grenade the one you have from not researching.
Link in my signature helps quite a bit, brohoss.
i agree with blue. before you go dropping pulley sizes do some flow mods and scan it. get a 3.8 and a 3.6 to have on hand when you get to the tuning so you can put it on once the tuner has tuned out your knock. he will then need to tune it again. and then come winter time again youll want to go up a size to get rid of the "winter" knock. 3.6 is probably the lowest you should go with the plog and DP. But the fact that you have a lift at your disposal will make the header install alot easier! you need to lower the rear of the subframe a few inches to sneak the rear in, and the firewall might need a little manipulating for the header dp if you go with the ebay or speed daddy ones. cars come from the factory with knock so your car definitely has some, the question is how much.
Or intercool and not care all year round.
