what is this ?????
grandprix5
Ok so during my cam install i found this little cylinder that i dont know what it is i need to know where it goes before i put everything back together this are some of the pics
<a href="http://s581.photobucket.com/albums/ss254/boundy_photos/?action=view&current=IMAG0068.jpg" target="_blank"><img src="http://i581.photobucket.com/albums/ss254/boundy_photos/IMAG0068.jpg" border="0" alt="Uploaded from the Photobucket Android App"></a>
<a href="http://s581.photobucket.com/albums/ss254/boundy_photos/?action=view&current=IMAG0067.jpg" target="_blank"><img src="http://i581.photobucket.com/albums/ss254/boundy_photos/IMAG0067.jpg" border="0" alt="Uploaded from the Photobucket Android App"></a>
<a href="http://s581.photobucket.com/albums/ss254/boundy_photos/?action=view&current=IMAG0066.jpg" target="_blank"><img src="http://i581.photobucket.com/albums/ss254/boundy_photos/IMAG0066.jpg" border="0" alt="Uploaded from the Photobucket Android App"></a>
<a href="http://s581.photobucket.com/albums/ss254/boundy_photos/?action=view&current=IMAG0065.jpg" target="_blank"><img src="http://i581.photobucket.com/albums/ss254/boundy_photos/IMAG0065.jpg" border="0" alt="Uploaded from the Photobucket Android App"></a>
That goes in the oil filter adapter with the long spring. Spring goes in the hole on the block and that cylinder goes on it.
Oh mfg thank you very much swiggles ;) i just found that pieze in the floor and i was wtf is this haha have you ever installed a cam??
There's no reason for that to be out when you are doing a cam install. That means your oil filter adapter must have been off.
yes ive done a cam install, did one last night infact. i take the motor out to do it, you dont have to though. heres a good write up on it.
Eric Buono's Cam Install
cam and balancer bolts can be reused, just put a little bit of loctite on them.
Ok well the reason the cylinder was out was becausr for some reason it was easier to disconnect the oil filter adapter because my turbo oil feed was ....long story short that came of so your saying that it goes on the oil adapter that goes stick to the engine cover and my car is all apart the only problem that im having its lowering the engine to get the cam out its there a different in lowering the engine from an old gp to a new gp mine is a 2005 how should i lower. The engine to get the cam out??
I will do my best to decipher this:
You removed the oil filter adapter to install the oil feed line for the turbocharger. The bypass cylinder and spring fell out.
You're asking about the procedure for lowering the cradle on a 2005 compared to a 97 to 03 GP.
I definately lost a few brain cells while reading that post. LOL
I'm about to lower one tonight for a cam swap. I did a newer GP last spring/summer and it wasn't anything different except. You didn't have to jockey two jacks, due to the oil pan being the motor mount. Lower down the passenger side and disconnect the strut from the body of the car, that will allow it to come down a little further. Now loosen the driverside to allow it to drop more. That should do it.
Funny Swiggs did a cam swap Sat-Sun and I'm doing one Mon-Wed.
Sorry about my stupid questions but its there any where i can find step bg step or pictures of the bolt and screws i need to take off in order to lower the engine because i dont really understand what bolts i need to remove to get the craddle down!!
Big round torx bolts & bushings - 4 of them I believe.
ANNNNNT Sorry...
Step by step to lower the cradle and swap a cam. I'm assuming you have all the engine disassembly ready. I prep everything first. Literally when I did this last night, the timing cover bolts were out, lifters were out, you name it..even the timing cover bolts and lim bolts have already been wire brushed for the sealant upon reassembly. Looking at the pictures again, I had the gasket surface cleaned and wiped, the cam thrust plate was off...I mean I lowered, slid one out, slid the new one in and poof..it was back up.
Jack and support the car from the body (aka drip edge where the metal is double/triple thick, refer to owners manual for jacking point if unsure)
Disconnect your dogbone mounts up top. Likely you only have the driverside on the car.
Remove the nuts from the passengerside strut tower (these hold the strut mount to the strut tower) 3 x 15mm
Loosen the 2 driverside subframe bolts 2 full turns these are 18mm bolts
Put a jack under the passengerside subframe and support it.
Remove the 2 18mm bolts from the passengerside subframe.
Lower jack until you can get the cam out.
Once the cam is out and the new one is in place, jack the frame back up. If it gives you trouble putting the passengerside bolts back in. Look at the front bolt locationa and note the hole behind it in the frame. Use an extension or pry bar to move the subframe and align the hole with the nut, then put your bolt back in. Reinstall the rear passengerside bolt and tighten the all of the subframe bolts. Reinstall the strut nuts. I found it easy to bring the subframe up, start a strut nut or two then align the subframe. Also note that I worked the jack with my foot as I guided the strut mount into the holes on the strut tower.
Yes..I know I make it sound easy. It feels easy when you've done it too many times.
Sorry grandprix5, was thinking of the lower control arm bolts.
Bill - get those pics back up for us.
Ok its nice that all you guys are helping me um juat waiting for paypal to refund my money because i bought a cam from a member here and he didnt send me anything im waiting to get the money back to get another cam so more questions will come haha
