Aw cm'on... It takes me a couple years to save $200 but I did... for the 2.5 DP w/cat and U-bend delete. factory flex joint sux almost as bad as the u-bend. I use an emulator. Ran that 2.5" on my GT about a year then swapped it onto the GTP. 2.5 is right for the GT, you won't lose bottom end you'll gain on top from that and the u-bend delete. When you go S/C it won't hurt ya, mine has rippy low end with one but I'm all the stock.Torn between ubend delete or 2.5" dp, rather not lose any low end if possible which is why the ubend delete is what im thinking unless i can find a dp for under 75
ABS pump running when not needed is the general thing a google search came up on that code. You have anything that will show wheel speeds while driving? If so drive around with someone watching for consistency across all 4, might be a bearing or a connection to a bearing.any one know anything about this code? c1276 - delivered torque signal circuit malfunction its a abs code.
so got my new master bolted on the the spare abs pump, then swapped the while thing out. bleed the master and abs pump, then went to the shop who last did my abs re home BS. he no longer has a snap on scanner that works and now has a aultel. good for European cars, not so much for domestic. so he cant re home it no more.
now to find a shop, 5 shops later no one has a tech 2 or snap on. im ready to pack it in but i stop at the shop across the street from me. guy has a snap on scanner. he hands it to me, and says have fun lol cool. i figure it all out, re home it fails, so clear the codes, it then fails again saying codes present. in the end i got the abs to re home, but i do believe this code i pulled is why my abs light comes on some times.
good news is, i now have a place i can go get free abs scans and stuff.
oh, and if any one is familiar with a snap on scanner, do you have any clue how to get to the steering settings. i tried to find it but came up short. the new rack is set to firm, i want it to turn like butter again.
C1276 Delivered torque signal circuit (serial data problem)
It's looking like it's the battery drain. Wouldn't hurt to check all your grounds and such. If it comes back it might be the EBTCM, the PCM (something in the tune), or a connection between the two. Most everything I found on the code is about Vettes, though.yup, all thats hooked up. im still searching too. thanks for looking around.
Also thats badass hes let you do it haha
I almost wonder if something is up with the EBTCM, it might be overheating like they are known to do. Well, at least the GTP stuff. Yours is kinda like the 97 GPs where the ABS is all integrated into the M\C, right?
Scotty go put new electrical tape over the ends of the split loom and out over the connectors on your hubs. Out back, if not also the fronts. Just in case because in my case it didn't take much moisture at all in that connector to confuse the ABS.
