What did you do to your Car today?
Status
Not open for further replies.
Installed ZZP voltage booster and high flow fuel filter. Amazed at how much the voltage booster helps! Woke the car up good. Next up for this weekend is a new hub for front left wheel, as well as a new axle shaft.
Seems to me like an electronic life decreaser, computers get hotter I'm sure. "the light that shines twice as bright lasts half as long" Obviously not twice as bright, but just a little with the same concept.
I'd prefer cleaning grounds and adding a second positive wire on the alternator(or larger wire) to decrease resistance, increasing stock capabilities. It does help, and is no strain on anything.
ha. i have no brakes at all......blew a line in the back of the car over the rear sub frame.
felt the pedal not holding at stops signs. then i parked it and stood on the brakes, yep, right to the floor, and hey, theres a puddle in the back. 2+2, still 4.
anyone know what size the back tubing is, ill be changing a chunk of line it seems.
i. absolutely. hate. working on breaks. I blew the back hose on my 1991 98 olds.. pain in the ass to fix! mostly because the tubing weird and the fittings that go into the breaks are a different size too.... now the back right hub leaks break fluid so its still sitting there. should fix it and drive it in the winter again for awhile. has some nice blazac tires on it.
picked up about 18 inches of brake line, and 2 compression fittings.
the boss fixed my no car issue by picking me up this morning, then letting me use his exploder to get home and then back in the morning. tomorrow should be a 1/2 days work or so. with any luck ill have this line fixed.
Drove it around town to get me some coffee and aquarium water today. Its so responsive now. As an added bonus it actually sounds like a V8 now ;)
Status
