What did you do to your car today? Vol 2.0
actually did something to the regal......i bought new plugs like 5 months ago or more. finally changed em sat. not to bad looking for 10-11 k on em. these plugs went in 3 years ago with the engine swap.
attachment.php
Productive sat/early sun. morning. Mom came out and took the kid out for the day/overnight on Sat. and dropped Dad off to help me with the Bonneville. Put about 12hrs into it (inc. lunch/dinner break). Got everything but the 2 pass. side doors sanded down and ready to go.
Of course nothing would be complete after 10+ hours of sanding on a car other than to find out that the steel return line is leaking fuel right where it bends upward in the back near the fuel filter. Found that after I fired her up and backed it into the garage so we could access the pass. side. Need to research that line because if I can get away with installing some fuel injection rubber hose on it and 2 hose clamps at either end then I may just do that. If not, then I'll have to figure out how to splice in new steel I guess. Oh well, at least I found it here and not out on the road somewhere.
Topped the GXP off with a half gallon of coolant & got trouble code P0332 for a knock sensor. Seems odd & I'm assuming the sensor will need replacing.
Added a quart of kaitlyn Jenner fluid. Really need to change the filter, gasket and output seals. This weekend was my cars new parts weekend that I’ve been carting around in the trunk, but, Saturday is valentines stuff with the mrs as I had to work today, then Sunday is a memorial for a family friend. Plus, I do need to go put in some work at the second “job”. Have a couple things to finish. The tractor and the chainsaw. Plus, the second job is the new wheels and tires money. Lol.
In the last month I've done brakes (front and rear), hubs up front, oil change, and supercharger oil change. Today the ABS harness for the driver front hub is supposed to arrive so I'll swap that out soon and also plant to shocks on all four corners within the next month. Also on the list is headlights and taillights as both are foggy and well worn due to age.
fuking bummer man.
Well, it ain't like anybody will notice I swapped to the GT. Hundred thou less miles.
During the fuel pump quittage-
With only first and reverse left-
My new, old ride. With stuffs swapped over. Been with me ten years now-
Chasing the sun in the 69 Saturday evening-
That Pantera at the shop turned out pretty sharp. It went home but I will see it again later all put together. The 351 has four Webers on top.
How does becoming a mother cow help? Not much of a shape shifter.
SD I think I have the cruise junk off the flipped GTP. So OK.
That was a joke. Like if a guy does engine builds, a cow does calf raises. Raising calves, calf raises... uh Heh heh
Might as well slap this vid here too for lack of a better spot. I have not swapped cruise modules or even looked yet. Who cares, the Catalina job came to life today. Look-
YouTube
