What a sorry job
Soviet
I do not know who done this to my car,it was before I got it.This deals with my windows control on my drivers door,my font passager is backwards u push it to go up it gos down and vice versa.To fix this do just flip the switch around or what. To add to that if u try to row the font passager window from its control switch it works right in thought of if push the switch to go up it will,but dosent go down at all.
At last the rear driver not working at all from that control.
What do I need to do to fix this?
Any write ups
Any tips on testing for what broke
Thanks for any help
Tough to understand what was done that caused the issue. Do you have a remote alarm/starter with window kit or something aftermarket in the car?
1.The car came with the problem.
2.yes, I have a remote now but I didnt have one at first.
3.the inside was stock when I got it eccept for a wire ran from underneath the car to the interior fuse box.
4, the car has always had the problem,before I took the wire out that ran from underneath the to to the interior fuse box and after.
Ok..so you don't know if this is just a bad switch or someone was in there messing around. Your post makes it sound like someone dicked with it and there's major rewiring done. That will scare most off the thread.
I do belive its someones f up wireing because the door panel is barely tore from were someone couldnt pop the pins out.
