were does this sensor plug in go?
thomasd2010
I have a 2000 pontiac grand prix GT and I couldn't figure out were the P.E.D #5 green color sensor goes right now its sort of hanging by the ignition module since I just did an engine swap. Anyone have any ideas? Thanks
The two wire connector at the diff cover would go to the VSS or speedo. A green plug back there would be the oil pressure sender. Not sure what you are talking about up by the ICM. Can you get a picture.
Well the only one I can think of that's close to the icm is the one that plugs into the radiator. Just look at your radiator and see if the sensor is plugged in. If so its not that one.
