weird noise when off the gas ...
ls1racer11
I have noise coming from the right front above 20 mph only when I let off the gas, like a rotational noise....any ideas?
If it is rotational and it seems to match the rotation of the tire, take a look at a brake backing plate rubbing on the rotor, movement in the hub/bearing assembly. It may be coming from the differential but i doubt it. Look for the obvious before digging in too deep.
A damaged thrust washer behind the sun gear in the differential will cause a noise when de-accelerating. When this washer/bearing "goes-out" it sends metal into the planet/ring/sungear chipping the teath, and the sun gear grinds into the diff.carrier, (audible noise). Metal will be found in the trans. oil pan.
Is there an easy fix?
"easy" is subject to opinion and experience, more of a PIA for me.
I had to replace the differential housing because the sun gear scored the surface the thrust washer sits on, and the teath on the sun/planet/ring gear were chipped, so I replaced the diff. with a good used one accuired from a local tranny shop, it was $200 with next day shipping to thier shop, I installed it myself.
Depending on wear/damage, gear teath, at the very least a new thrust washer has to be installed, and all the metal cleaned out of the pan. Fortunate for me, the magnet in the pan was directly under the fluid return hole from the diff. and captured most of the metal fragments. I changed the trans. filter and refilled with fluid, all has been fine since then.
