ls1racer11
I have noise coming from the right front above 20 mph only when I let off the gas, like a rotational noise....any ideas?
A damaged thrust washer behind the sun gear in the differential will cause a noise when de-accelerating. When this washer/bearing "goes-out" it sends metal into the planet/ring/sungear chipping the teath, and the sun gear grinds into the diff.carrier, (audible noise). Metal will be found in the trans. oil pan.
"easy" is subject to opinion and experience, more of a PIA for me.Is there an easy fix?
