reesez
yes I searched. My 99 GTP makes an odd noise over 30 mph and gets louder around 60. It mostly goes away when turning wheel right, prominent when turning left. Sounds like it is coming from the front left? Checked all bearing play on front and it's tight. Checked my rear and the right rear was loose so I replaced it. Not AS loud now but still there. It vibrates pretty bad sometimes cruising at speed on interstate, about medium when accelerating. When I decelerate it makes a howling noise. Would my axles make a grinding/whirring noise like this? When I had it aligned they said my axles were loose and had play in them but that was months ago. I do know that both my front strut mounts are shot, and my driver side strut bearing is seized and turning the spring when I turn. My engine and tranny mount are also blown. Any ideas are appreciated, thanks!
