Weird Issue
I just noticed that the vacuum line to the evap canister is missing that couldn't cause a misfire could it? And where the heck is the evap canister at anyway, I couldn't find it.
evap canister sits behind the blower.. its pointless bull****... but id fix teh vac leak.. doubt its the misfire cause but i could be wrong.
Something real similar to this happened to my friend just recently, he had a miss on cyl #5 and replaced everything and couldn't figure it out for a long time. It turns out in the end that his fuel trims were bad. We then Put the stock PCM back in an it ran perfect.
So I drove the car halfway across the state for work, then scanned it when I got home, now its putting up the code P0300 random multiple cylinder missfire. So I am more convinced that it is indeed a bad ICM.
Well a little update on this here is a list of things I have replaced/removed trying to figure out wtf is going on.
  • Checked 800 times for vacuum leaks
  • New Autolite 104's gapped at .055
  • New Premium Wires
  • Swapped out all the coils twice
  • Swapped out the icm twice
  • Removed the cat
  • Removed Egr
  • Swapped injectors around
  • Replaced all the orings
  • Replaced new Powerbond SFI Harmonic Balancer
  • Replaced Crank Position sensor
Still have random multiple misfires.
This screen shot is from the car idling after a 15 min cruise down the highway. I tried to get a scan but when I opened the file it was blank :confused:
Replaced Cam Position sensor today and still random multiple missfires........ that leaves only 2 more things that could be wrong the computer is bad or I have multiple chipped pistons.
Went for a cruise down the highway for about 15 min, and my Timing Advance is all over the place while cruising its anywhere from 0* to -29.5* LTFT1 was pretty constant at -8.53975% had a short blip for a few seconds to -7.8125%
Even with that thumbnail post I can still see the damage. So you just noticed this recently?
