WBS shift kit...
Bogers99GTP
Anyone have any experience with the W body store shift kit? Dosen't look as complete as the other shift kits out there.
Depends on which you use. Some actually increase the life of the clutches by reducing how much they slip between shifts.
ahh I see I see. So my car is kinda hesitating before grabbing second under normal driving conditions... Like, I feel it let go of first and motor sounds like its got no load then rpms drop and I got second gear... That would be something with my Solenoids, right?
ZZP's is only spacers. Intense's is all new springs, spacers, detailed instructions, seals, accumulator gasket, hell even sandpaper to scuff the accumulator walls. It's everything you need, except fluid.
:eek:
Its all that needed though?
Yeah I had gotten the W-Body shift kit some time ago and it was ONLY 4 plastic tubes that slipped over the pins and nothing more. USELESS! I got the Thrasher Shift Kit, and it has new springs, brass tubes and instructions, plus it gives you THREE different settings for the type of shifting you want!
If you think cost of their shift kit is cheap? Well the product they sell you is definitely CHEAP! Stick with the Thrasher, or Intense kit. You won't be disappointed!
