Washer Fluid Injection
98GT3800
I didnt believe it. I went to my shop put some washer fluid in a spray bottle-on a super pfine mist, with a lighter it sure enough does.
Now who is running it, i know it sounds silly. Is anyone running on our v6's. Im just curious to see the outcome on a non SC or Turbo CAR.
Id like to see some pics though and parts used. Just out of curiousity. THANKS
It is the same concept as water/meth/alky injection. I have read of this being done plenty with the cold weather washer fluid.
With one of these kits are there any kind of supporting mods you should have first or can anyone just go slapping on a meth kit?
ALSO my question. Found the kit i want but what else do i need "supporting mod". or is just this kit fine. Also when the say water/meth/alchy that meas i can use any of them but drain all of the other before switching right.
Im sure like nitris i need a colder plug. Any other advise would be great or forwarded to another THREAD.>>
thanks
You don't need colder plugs, just a tuner to help you with it. If you start out straight washer fluid, use a smaller nozzle because you don't want to retard the combustion flame too much....the more methanol you use the bigger the nozzle you want to use.
But if you want to put it on your GT, it's pretty much pointless. Forced induction is where this helps out.
Ok, really thats what i was wanting to know, i should have asked that. i was looking in to SCing it but i didnt add that in. THANKS
