Washer Fluid Hose Replacement
UCF04GPGTPCompG
Anyone know the length of the washer fluid hose for a 2004 GP? Mine has cracked in like 10+ spots and while I can patch it with a larger hose around it, it's getting to be quite annoying. I want to replace the hose now but measuring the length is annoying, but do able.
Outside of that, does anyone know how to access the back of the washerfluid pump so I can disconnect the hose? I figured I could try from the passenger wheel well, I hope I don't need to take off the entire front bumper.
I'm probably going to buy replacement hose from AutoZone of AdvanceAutoParts, or some other similar place if I can find the length I need. I believe the diameter is 5.5mm or 7/32''. Thanks for any help.
You can access it through the wheel well. You'll just have to remove the well linear. Its held on by a bunch of 10mm bolts
I'll remove the liner, that's how i thought I could get to it but wasn't 100%. I'll measure with a string the length and buy replacement hose from an autoparts store. I think if i used a junkyard part it would have just as much sun damage as my current hose has.
when I bought my 07 it came broke, so I took a oem off a 01, works great
but I do hear what your saying, even at a part store cost is minor
