UCF04GPGTPCompG
Anyone know the length of the washer fluid hose for a 2004 GP? Mine has cracked in like 10+ spots and while I can patch it with a larger hose around it, it's getting to be quite annoying. I want to replace the hose now but measuring the length is annoying, but do able.
Outside of that, does anyone know how to access the back of the washerfluid pump so I can disconnect the hose? I figured I could try from the passenger wheel well, I hope I don't need to take off the entire front bumper.
I'm probably going to buy replacement hose from AutoZone of AdvanceAutoParts, or some other similar place if I can find the length I need. I believe the diameter is 5.5mm or 7/32''. Thanks for any help.
