    TIPS:
Wanted modified fuel rails, fuel logs, and a braided fuel line setup.
suitercrew
Just like title says, looking for some kind of modified rails or logs like prj. Also if anyone has braided lines to go from hard lines to quick connects that would be cool. Thanks.
Sent from my LG-H901 using Tapatalk
you can cut and mod a stock rail for about 20 bucks or so. you could also use a flair tool and unions. been running this for over a year now, no issues as is.
Well although I trust your setup performs just as well as any I care slightly to much for aesthetics to run something similar to what you have. Even though it's probably going to end up costing me an arm and a leg :( but thank you Scotty for the idea
she got a black front cover now lol dealer said noting about my mods. lol dumb ass guy left my plug wires dangling in th ewind, so i went back in and got my plug wire holder back from the trash can and re installed it in the lot there lol
I mean your right it's not very notieceanle but I still think it would really bother me. I would have just bought the zzp one but they trick you. The price says 150 then it's 50$ extra for the l67 and then a 50$ core fee. Like serious f*ck off zzp you shady b*stards. I was looking into getting those automotive fuel logs but really it's just pointless people have 400whp setups on the stock rails so obviously they don't have a flow issue so why would I spend 350+ on fuel logs. Grr
Well they modded rail is really short and the line is braided stainless so I doubt it's going to come apart or anything with rubbing. Scotty what ic core are you running?
the one thats sold here. regal hood might come down more. seen a gsx stage 3 regal here local with a ssic and injector spacers, his rail was deep into his foam.
i got it used from marshal, and pretty sure he got a hood scoop install because of the rail rubbing. he'll chime in maybe.
not sure, ive not been around very many gp's in person.
Well from everything I've researched there shouldn't be any clearance issues even with a fsic and a stock gp hood. Now if you have a gen 5 setup then you might have clearance issues
gen 3. and the vac manifold has made a hole, the plug wire clip on the snout has made a hole, the top of the tb bracket and the bbv as well all hit and made holes, add a fuel rail over the top thats gonna sit a 1/2 higher and its gonna hit the hood, not the foam on my car.
i also have very solid mounts. so maybe my engine sits a bit higher due to that.
