Want to make sure I'll be ok
both, its a game to play on what works. I had to double stack the foulers on my last car to get it to work.
Just my 4 cents, I had to use a washer to get my EGR to fit the SDs because it wouldn't bolt flush to the header IF you reuse your OEM gaskets. The SDs gaskets actually extend to the EGR tube to fill that gap.
You should use both foulers anyway. One drilled to fit the sensor, one not.
Drill it to be about a half an inch right? And then you leave the one that's closer to the exhaust the same?
