Want To Add Trans Cooler
My LS4 stays that cold in the cold of winter(110 to 120 degrees 45 minute commute), Hayden 679 trans cooler inline with the factory cooler. Average summer temp is around 180, before the cooler was added it would reach 220 easy. I don't drive it in the winter anymore, but those temps were too cool in my opinion .
I never drove my GXP in the snow/frigid cold...so I just know in the Missouri heat/humidity it never saw 190* again, let alone it barely crept over 180* beating on it all afternoon.
Thanks for giving a real world example with the LS4 and the 4T65E-HD tranny with a trans cooler. As stated earlier if you size the cooler (S) to the heat reduction required with a proper installation, any transmission will see a dramatic reduction in temperature regardless of the engine in front or along side the tranny. I looked up the GVW rating of your tranny cooler which is 30,000 GVW (decent size BTW) but you could easily see another 30 degree in drop in the summer by separating the tranny cooler from the in radiator cooling, and allowing the tranny cooler to do all the cooling like it does in my 3 cars. My guess is that the average coolant temp for that LS4 V8 if similar to other GM V8's like my LS7 is about 210 degrees. The reason the tranny temps are so high on stock trans radiator cooled LS4's is that the very hot tranny fluid is attempting to be cooled by coolant that is 210 degrees.....WAY TOO HIGH AND HOT. The ideal tranny temp despite what is often published is not around 180 degrees. it is around 140 degrees for all year round driving but often difficult to achieve with just 1 cooler ( I have 2 Long Dana coolers on my GP and 2 coolers on my Mustang GT as well outside of the radiator cooling...stand alones). You could easily drop another 30 degree reduction with your setup if you allow the Hayden cooler to do all the trans fluid cooling outside of the radiator.
My 01 GP has 205,000 miles on the tranny with the 2 coolers doing all the cooling outside of the radiator and I drive the car all year round in VERY cold weather. The only issue in very cold weather is that the tranny needs about 3 miles of gentle driving when below 20 degrees outside to shift in OD since the fluid takes longer to heat up under those conditions....well worth this minor delay. The Long/Dana coolers with built in temp control never let the fluid drop below 120 degrees. If you do not drive the car in the winter anymore, I certainly would have the cooler as a stand alone outside of the radiator since 180 degrees in the summer is still too high, in my opinion based on 35 years of adding coolers on my personal cars...........The number #1 killer of any transmission is HEAT followed by dirt (change the fluid/filter often @20,000 mile intervals and the 4T65E will live a long life.)
Well I am not debating your findings, I too have been adding coolers to cars for 30 plus years with what I think are good results(most cars don't have transmission gauges so I really only know for fact the difference of a handful of cars), but the other end of the spectrum is getting too cool for the transmission to operate correctly. We both agree 200 or higher is too high, but I feel 180 degrees is better than 125 to 140. I have a thermal bypass for the car I have not installed because of no winter driving, but even that is set at 180 degrees. Bottom line is lowering temperature, and the LS4 suffers more than most cars from this because the engine compartment heat soaks. I may give it a try stand alone at some point(right now is low priority for that car), its a better way to go but for me with the cooler I have driving in the temperature I was it works. Different geographic locations need different set ups. On a side note my 2004 Comp G daily driver with a similar set up cooler never got to 180 since installing a couple years ago, that car has a more direct airflow path to the cooler where it is mounted also due to the front bumper opening . If I change something I will post back any differences. Good luck to the op with whatever they choose.Pics of both.
GXP
http://www.hostthenpost.org/uploads/7cffce5d8f8a24fd9cad476afa6b7df9.jpg
Comp G
http://www.hostthenpost.org/uploads/ff0d3b3e5058c1a53adf6b0ad3da6473.jpg
Yup; Mine bypassed the radiator as well.
Still wasn't anywhere near 140* in real world driving in the Midwest.
LS4 Nation on facebook?
LOL.
97% of those people think the LS4 is made of gold so this is coming from Triple Edge; someone who BUILDS the transmissions that the 4590 is PLENTY for the car.
LOL.
Yeah on fb lol talked to 2 members that use the 4590 on there gxps i booked it for wednesday for the install 😁😁
Trust me; it'll work just fine.
The people that tell you it's too small apparently don't understand how common sense works.
As stated before, the cooler should be sized to the desired tran fluid temp you are looking to achieve. If the fluid gets to that temp with a particular cooler, then it is sized correctly. If the trans fluid temp does not, it is not sized correctly. There is no one size fits all trans cooler. There are many factors that will effect it efficiency to cool the trans fluid adequately. On my GP, I have 36,000 GVW cooling capacity. I would think that on an LS4, one would need at least that much, probably more like 42,000 GVW cooling. The target trans fluid temp should be between 140-160 degrees for maximum tranny fluid and trans longevity.....
Actually; the target temperature for the 4T65E to prevent any premature damage is 170* (from GM). Anything less is just like revving a cold engine. 140-160 is too cold.
I guess my tranny @ 205,000 miles on it has been operating like a cold engine for the last 115,000 miles with the 2 Long/Dana coolers hooked up. The trans fluid rarely gets above 140 degrees. It shifts today like it will easily get to 250,000 miles. Hard to argue with success and real world experience....
140* is to cold. The thermocoupler in the cooler is 180*. Running two coolers, well, they are just fighting each other.
I just programmed my fans to come on at 195. Everything reaches working temps in the winter at the same speed, but the coolant hits temp before the trans fluid in the summer kicking the fans on and keeps the trans always a few degrees cooler.
Who is giving bad advice?? If you disagree that is your right, but my suggestion is based on facts and my experience with 3 different cars running coolers where the tran fluid temp is 140 degrees or less. One tranny is a GP with 205,000 miles on the tranny. Another example is a tranny not known for longevity with 150,000 miles on the tranny. Both examples run tranny temps well below 140 degrees. If the OP has a 4T65E with an LS4 and wants it to live much longer than the usual longevity, run external coolers of high GVW capacity outside of the radiator cooling, install an external filter in line with the fluid, and change the fluid/fillter often (15-20,000 miles). The tranny will last a very long time.
like he said, 140 is not hot enough. and hes right too, your 100% wrong here.
so take one extra cooler off the car.
theres a chart floating around with the optimal temps, and what happens to a cold or to hot tranny. you really want to be 170-190 ish
You really need to broaden your information base....Last word on this topic for me!
Do some search beyond GM vehicles and you will find many tranny's that routinely run 140-150 degrees normally and lower especially when not under a severe load which is most of the time. The tranny's in truck and some SUV's run these temperatures all day long....when not stressed. Most car documentation stresses that 175 is the upper limit for longevity of transmissions..the upper limit!
Don't mean to hijack, but my question is similar enough not to start a separate thread. I'm also interested in installing a transmission cooler setup to keep my trans at an optimum temperature, but my car has to deal with an extreme range of temperature. I live in AZ, and during the summer, the air temperature is regularly 95F+, with frequent trips climbing hills in 120+. I do not have an aftermarket trans temp gauge installed, but just crusing around this summer, the temp on the info center is usually maxed (I think at 197F?). In the winter here, temps get down into the teens. Are there any special considerations for my climate, other than what's already mentioned? The car is a factory-stock 08 GXP with 78,000 miles on it. I've only had it since March, and I've had zero problems with the transmission performance, but the fluid is already starting to turn brown. I want to keep this thing alive. Also of note, when climbing the steepest parts of my usual trip, the coolant gauge does tend to head near the red, even with the a/c off.
