W body noob
Performance nut
Hey all. I've owned my 2008 Grand Prix GT for years now and honestly, I'm looking to make it handle better. I browsed around the forum and saw some stickies that answered some questions but a few remain. It seems the 2008 is a real oddball and what works for older models may not work on my car. So, I figured I would be very specific and ask about the 2008.
Tower braces seem like a great start as do the addition of better sway bars. If that works out, I'd like to look into ugrading further, like coil over struts. The sticky at the top rated braces and sway bars very high and the write up was exactly what I'm looking for. So my questions are 1) which size sway bars work well for a 2008 and 2) are there problems with these upgrades (need additional mods, very hard to find parts for 2008, need to remove x to install y, etc). Thank you all for your advice.
dorman front bar and addco rear.
GMPP set is smaller and hollow, but significantly cheaper.
AGX struts or bilsteins.
Bilsteins are better, but once anyone sees the price, they bail.
over one?
You mean over 5 right?
Hell, factory GM mag struts are worth 2 a piece.
Most jump ship on the factory mag system when one fails and opt for something like Pfadt coilovers. They start at 2 a set and work up to over 5.
But this is where you have to seriously consider if a W body is really worth it.
over one?
Right. I can't find the rear sway bar. Looked several places and couldnt find one. The front one was easy to find and not a bad price either.
Edit: This is what I meant by systems over $1000 http://shop.zzperformance.com/store/p/595-Coil-Over-Strut-Package-for-Wbody.aspx
Fairly certain it will.
Sway bar links, brackets and bushings appear to be same part number.
TLSheff works at a dealer, perhaps he can check this out for us?
Sweet, that would be nice to know. Can not find anywhere that lists a rear sway bar for a 2008. Moog only makes front links up to 2003, so knowing if those are different will help as well.
You'll have to go check your vehicle, but there are two front sway bar/LCA designs for the 97-08 cars.
in 04 to sometime in mid 06 they switched from LCA mounted sway bar to strut mounted.
They apparently switched back sometime during 06. Yours should have the old style, but its worth checking.
I was able to take a pic of the rear sway bar. I'm not sure what the difference is between the 2003 and 2008 rear sway bar is and I'm hoping a picture helps. The Addco bar shows 1998 to 2003 Grand Prix.
